Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Toolbar appears blacked out
25 REPLIES 25
Message 1 of 26
5827 Views, 25 Replies
My toolbar suddenly black out when I opened it. I was able to use the software fine until I reopened it and the toolbar blacked out. I have tried uninstalling and reinstalling but the issue is still there.
Here is a screenshot for further detail. I can still click the functions of the toolbar and everything works but the toolbar is blacked out.
Labels (3)
25 REPLIES 25
Message 2 of 26
dsouzasujay
Hi @Anonymous ,
Can you try a solution provided by @lance.carocci .
In Message 29
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Message 3 of 26
in reply to: dsouzasujay
I am unsure of the instructions specified in his comment.
  1. Right-click on My Computer/This PC on the Desktop or in the Start Menu and select “Properties”
I am not sure what he means by this.
Message 4 of 26
I was able to figure it out.
It now works and the bar is not blacked out anymore.
Super weird but I guess it works.
Thank you!
Message 5 of 26
dsouzasujay
Hi @Anonymous ,
Follow as below image
  1. Right click on My PC and select 'Properties'
  2. A 'System' window will appear, Select 'Advanced System Settings'
  3. A 'System Properties' window will appear, Click on 'Environment Variables'
  4. A 'Environment Variables' window will appear, Under 'USer Variables for <Your Username>, Click 'New'
  5. Add below details, hit ok
Sujay D'souza
SQA Manager
Quality Assurance
Tags (1)
Message 6 of 26
dsouzasujay
Oh.. i see you have figured it out 😀
Sujay D'souza
SQA Manager
Quality Assurance
Message 7 of 26
lance.carocci
@Anonymous please gander at these screenshots for guidance, and let us know if you have any questions.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 8 of 26
I had the same problem and the other solution (involving navigating to "My PC" and messing with properties) did not work for me. What did work was just moving my mouse around under the black bar covering the toolbar and finding the workspace button. If you can manage to find the button and switch workspaces, this fixed the problem for me. Silly, but seems to work consistently. Hopefully this helps someone.
Message 9 of 26
I have the same problem (started when I installed the update), and this isn't working. Is there anything else I can try?
Message 10 of 26
I just got it: I played around with visual effects in system properties
Message 11 of 26
dsouzasujay
Hi @Anonymous @Anonymous ,
If above solution is not working.
Restart your PC and try to launch fusion 360
If you still see the same issue, then
Please Remove/edit below Environment Variables
  • Variable Name: QT_OPENGL
  • Variable Value: software
And add below Environment Variables.
  • Variable Value: angle
Sujay D'souza
SQA Manager
Quality Assurance
Message 12 of 26
beatNXAMS
@dsouzasujay @Anonymous  This solved the problem on my computer - thanks!
(Sorry I can't find the "accept solution" button.)
Message 13 of 26
dabisdris
Item 5. details are impossible to read since resolution is bad. Zooming in doesn't help.
Can you place the field info in the the instructions you listed?
Message 14 of 26
dabisdris
I found the correct variable further down in the thread:
All is well now. Thanks.
Message 15 of 26
hansen.95
None of these solutions is working for me.
  • Environment variable QT_OPENGL with value "software"
  • reboot
  • Environment variable QT_OPENGL value "angle"
  • reboot
  • changed workspace multiple times
  • under system properties - performance options - visual effects, selected "Adjust for best performance"
  • update graphics driver (Intel HD Graphics 620 to driver version 27.20.100.8681)
Any suggestions?
Message 16 of 26
I'm having the same issue. Please Help
Message 17 of 26
dsouzasujay
Hi @Anonymous @hansen.95 ,
When you Launch Fusion 360, Are you seeing Same Black screen?
Can you please attach your environment variable window screenshot?
Sujay D'souza
SQA Manager
Quality Assurance
Message 18 of 26
alex.trudel
It worked for me! Thank you
Message 19 of 26
Great, Issue solved.
Message 20 of 26
This solution worked for me.
