My toolbar suddenly black out when I opened it. I was able to use the software fine until I reopened it and the toolbar blacked out. I have tried uninstalling and reinstalling but the issue is still there.
Here is a screenshot for further detail. I can still click the functions of the toolbar and everything works but the toolbar is blacked out.
Solved by lance.carocci. Go to Solution.
Solved by dsouzasujay. Go to Solution.
Hi @Anonymous ,
Can you try a solution provided by @lance.carocci .
In Message 29
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souzaI am unsure of the instructions specified in his comment.
I am not sure what he means by this.
I was able to figure it out.
It now works and the bar is not blacked out anymore.
Super weird but I guess it works.
Thank you!
Hi @Anonymous ,
Follow as below image
Sujay D'souzaOh.. i see you have figured it out 😀
Sujay D'souza@Anonymous please gander at these screenshots for guidance, and let us know if you have any questions.
I had the same problem and the other solution (involving navigating to "My PC" and messing with properties) did not work for me. What did work was just moving my mouse around under the black bar covering the toolbar and finding the workspace button. If you can manage to find the button and switch workspaces, this fixed the problem for me. Silly, but seems to work consistently. Hopefully this helps someone.
I have the same problem (started when I installed the update), and this isn't working. Is there anything else I can try?
Hi @Anonymous @Anonymous ,
If above solution is not working.
Restart your PC and try to launch fusion 360
If you still see the same issue, then
Please Remove/edit below Environment Variables
Sujay D'souza@dsouzasujay @Anonymous This solved the problem on my computer - thanks!
(Sorry I can't find the "accept solution" button.)
Item 5. details are impossible to read since resolution is bad. Zooming in doesn't help.
Can you place the field info in the the instructions you listed?
None of these solutions is working for me.
Any suggestions?
Hi @Anonymous @hansen.95 ,
When you Launch Fusion 360, Are you seeing Same Black screen?
Can you please attach your environment variable window screenshot?
Sujay D'souzaCan't find what you're looking for? Ask the community or share your knowledge.
