Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Texture mapping is off on fillet corners
2 REPLIES 2
jp9DNHT
676 Views, 2 Replies
There seems to be an issue with textures on fillet corners. The texture is rotate 90 degrees. The manual adjustment of all the separate faces is cumbersome plus doesn't always stick, meaning it sometime rotates back to the wrong alignment after resisting a part.
2 REPLIES 2
jeff_strater
in reply to: jp9DNHT
are you using the body-level texture controls (right click on the body):
This command applies texture mapping to the entire body, with several modes to choose from:
Seems like Box mode would be most appropriate to what I see of your design.
Jeff Strater
Engineering Director
That's rarely a solution. It comes down to the fact that Fusion 360's texture mapping is just simply pretty crap.
You're never going to get your maps to look right with these clunky controls. But even for something as basic as wrapping a texture around half a cylinder to a flat plane Fusion can't even get right. Never mind OPs problem.
