Im struggling with trying to create a logo stamp for a 3D printer from an SVG image.
Every time I import the image as SVG there appear to be some blue triangles appear in various parts of the image, which when I click on teh spaces to extrude, highlight multiple sections of the image that I dont want. Presumably some sort of selection area?
Ima total newb and inexperienced at Fusion, so Im really struggling. People have suggested that the SVG isn clean, but I have gone into illustrator and checked the paths, and they all appear closed, and Ive thicked the lines to make sure they are visible easier... Yet no matter what I do, I cant get it to work...
Everytime I tweak the image, a different section now has the blue triangles over it...
Is there a way to get rid of these selection triangles? Have I completely screwed it up? What am I doing wrong?
Any help greatfully received....
Solved by g-andresen. Go to Solution.
Please share the file.
File > export > save as f3d on local drive > attach it to the next post.
günther
Please also attached the SVG file as well.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Ive attached the first one I have had problems with, which has the words... I may have solved the issue by removing teh words but it isnt exactly what I want lol... Thanks for the help
I have deleted several double lines in V-Carve and reimported them into Fusion.
try again
günther
