Ever since fusion360 student moved to cloud analysis, I haven't gotten the static stress simulation to work. I keep getting failed analyses. I urgently need this feature to work for my project. Please Reply someone. Attached is an image of my current problem. My model is a simple beam, and no complexity exits.
Does this happen for a solve in the Cloud or a local one?
Are these the full contents of the report you receive? Is there any other error log above the lines "Error: Solver Error | Error: An error occurred while solving the model"?
Which OS are you using? If it's windows, do you have any non-English characters or a space in your username?
If you are using Windows OS, please start off by making sure that you run Fusion 360 with Administrator rights:
@sutherland- wrote:Does this happen for a solve in the Cloud or a local one?
…please start off by making sure
First line of the problem statement.
This is only a problem with cloud based simulation. That's the only one students have access too. There are no errors above the error line. Everything works well until receiving the results; that's where is fails. I use windows 11
I changed to administrator but it did not fix it. Same error still appearing.
It doesn't really help you but the simulation worked for me. Maybe it's a Win11 issue. I am on Win10.
