Static Stress Simulation Keeps Failing
freecadali14
freecadali14
Ever since fusion360 student moved to cloud analysis, I haven't gotten the static stress simulation to work. I keep getting failed analyses. I urgently need this feature to work for my project. Please Reply someone. Attached is an image of my current problem. My model is a simple beam, and no complexity exits.
Replies (9)
sutherland-
Hi @freecadali14
Does this happen for a solve in the Cloud or a local one?
Are these the full contents of the report you receive? Is there any other error log above the lines "Error: Solver Error | Error: An error occurred while solving the model"?
Which OS are you using? If it's windows, do you have any non-English characters or a space in your username?
If you are using Windows OS, please start off by making sure that you run Fusion 360 with Administrator rights:
  1. Right-click on Fusion 360 Desktop Icon
  2. Select Properties
  3. Select Compatibility Tab
  4. Enable Run this program as administrator option.
Please click on Accept Solution so other community members can see how to solve the issue.
Also, consider giving a Like to the comments that you feel helped you.
Best regards,
Level  sutherland-
Member
TheCADWhisperer
@sutherland-
First line of the problem statement.
@freecadali14
freecadali14
This is only a problem with cloud based simulation. That's the only one students have access too. There are no errors above the error line. Everything works well until receiving the results; that's where is fails. I use windows 11
I changed to administrator but it did not fix it. Same error still appearing.
freecadali14
I've attached my file named "Simple.f3d"
wmhazzard
It doesn't really help you but the simulation worked for me. Maybe it's a Win11 issue. I am on Win10.
freecadali14
Your solution did not work, sorry
freecadali14
Are you using the student version
wmhazzard
No, paid version.
freecadali14
Yah I have student so there’s the difference
