Spline not staying in 2D plane
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a sketch with a simple rectangle and a spline replacing one end (so a rounded end to the rectangle).
When I try to extrude it, Fusion would not allow me to select the plane. After 2 days of googling all I can assume is that some of it is off plane and now 3D.
When I delete and recreate the spline, when I adjust the end point things to adjust the curve, when I finish the sketch, it draws completely differently...and when I revolve the drawing I can see that it has gone somewhere in 3D.
I have the option "3D Sketch" turned off (unchecked) and the preference "Design - Allow 3D sketching of lines and splines" also turned off.
Is this a bug with Fusion? It means I cannot use it to create a simple spline and extrude it.
My sketch does have some elements from another sketch projected onto it.
I have tried recreating a sketch with the similar items - a projection and spline - but it seems to work. So why is it not working for my other sketch? It seems to be ignoring the options and preferences. I have tried closing and reopening the sketch and Fusion.
