Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Sheet metal part unfolds but errors in flat pattern
2 REPLIES 2
Sophi9999
211 Views, 2 Replies
I have a curved sheet metal part that will unfold.
Once unfolded, I cut a shape and add a hole.
I want to make a flat pattern for laser cutting, but it errors on this operation, saying there is a compute problem.
Workflow is in screen cast and f3d is attached. Thanks in advance!
Labels (1)
2 REPLIES 2
daniel_lyall
in reply to: Sophi9999
It is the intersect extrude doing it (your second extrude on the timeline) draw a squire around the cut sketch and edit the extrude and select the area inside the squire as the cut tool instead of intersect.
@jeff_strater Could you please have a look at this.
Example attached.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
Sophi9999
I tried this suggestion - using cut instead of intersect.
I am able to unfold but I am still unable to export a dxf.
Any ideas why?
