Hello
I encountered a problem that the DFX file is imported and displayed not correctly. (I save the DFX from autocad)
What am I doing wrong?
Or FUSION basically can't display curved lines from dfx correctly?
Solved by g-andresen. Go to Solution.
Please share the files > f3d and DXF.
File > export > save as f3d on local drive > attach it to the next post
günther
The DXF was inserted at a great distance from the origin.
I have brought it back again.
günther
Oh yes!
I guessed it was too far from the beginning of the coordinates, the same problem occurs in 3d max.
But in fusion I couldn't find where to see the current coordinate value. Thanks to your answer I figured out the question and now it's not a problem for me ))))
thank you
How to align or move bodies to the Origin in Fusion 360
1. alignment does not work with sketches
2. When inserting sketches, leave the origin visible.
günther
