Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Saving to STL
2 REPLIES 2
wo009b0742
206 Views, 2 Replies
Saving to STL
I have noticed recently that saving a design to STL to print is taking several minutes and I can only export once. I have to exit the software and then open it, load my design to then export another part of my design. Is there a fix for this behaviour?
2 REPLIES 2
jhackney1972
in reply to: wo009b0742
You should use the Save as Mesh command instead of Export.  It is much more efficient and offers some advantages.  Select your Body in the Browser, right mouse click and select the command.  Set you desired parameters in the dialog box (not shown) and save your file.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Phil.E
There is a new build of Fusion that should have a fix for this. Can you please update Fusion to build 2.0.18220, which was released yesterday, and let us know if the issue is solved for you?
How to update Fusion
Phil Eichmiller
Software Engineer
Quality Assurance
