Announcements
Unable to export STL
cyrus.dalal8P5DW
cyrus.dalal8P5DW
I'm running into a problem where the STL export status stays at 0% indefinitely. This is happening on multiple computers on this account. Both computers are running the latest Fusion 360 update.
If I restart the program it will successfully export the STL one time. Every attempt thereafter hangs. If I restart the program I can get it to export again once. Any help?
RajkumarIlanchelian
@cyrus.dalal8P5DW We are looking into this issue which seems to be random and we are trying to understand what the root cause could be.
one easier workaround for now is to right click on the body that you want to export in the browser and save as mesh. This will work more consistently and get you what you are looking for until we can identify what is causing this issue.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Phil.E
There is a new build of Fusion that should have a fix for this. Can you please update Fusion to build 2.0.18220, which was released yesterday, and let us know if the issue is solved for you?
How to update Fusion
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
