Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Save does not work
4 REPLIES 4
martin98TKG
328 Views, 4 Replies
Save does not work
martin98TKG
Observer
Observer
After succesfull install save does not work. In data panel the progression icon just rotate avd i I try to save, hitting Ctrl+S, nothing happens. If I try to closae the application I get Usave changes and clicking Save I get Save Receiving data... and nothing more happens. Inter connection works fine.
Save does not work
Tags (2)
4 REPLIES 4
RajkumarIlanchelian
@martin98TKG Can you please try the below?
1. Logout and close Fusion
2. Go to https://login.autodesk360.com/login
3. Login
4. This should ask you to create your team hub
5. Once that process is complete, can you now login to Fusion?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
3. Login
Autodesk Fusion
Join Fusion Insider
martin98TKG
Observer
Observer
Thanks for help. Yes, it solved my problem.
With kinf regards, Martin
Frosty11
in reply to: martin98TKG
Frosty11
Community Visitor
Community Visitor
I'm having the same issue how do I log out shut down fusion without losing my work that I couldn't save?
RajkumarIlanchelian
@Frosty11 Unfortunately you may not be able to do that. You will first need a team hub before you can save.
Autodesk Fusion
Join Fusion Insider
Autodesk Fusion
Join Fusion Insider
