After succesfull install save does not work. In data panel the progression icon just rotate avd i I try to save, hitting Ctrl+S, nothing happens. If I try to closae the application I get Usave changes and clicking Save I get Save Receiving data... and nothing more happens. Inter connection works fine.
Solved by RajkumarIlanchelian. Go to Solution.
@martin98TKG Can you please try the below?
1. Logout and close Fusion
2. Go to https://login.autodesk360.com/login
3. Login
4. This should ask you to create your team hub
5. Once that process is complete, can you now login to Fusion?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I'm having the same issue how do I log out shut down fusion without losing my work that I couldn't save?
@Frosty11 Unfortunately you may not be able to do that. You will first need a team hub before you can save.
Autodesk Fusion
Join Fusion Insider
