So the last couple of days my rendering gallery have been buggy.
The problem: My render gallery (on the the render tool in fusion not online) is back by one or two renders. If I want to see my current rendering I have to render one or more to actually see the first one I wanted to see.
The slider is all the way in the beginning. I restarted fusion several times now. Really odd problem to have.
Anyone knows how to fix it?
Solved by saito.kh. Go to Solution.
Hi @laurivisnapuu,
Thank you for posting in the community!
It's really odd! Did this happen with a particular model or all the files?
If this happened with a particular file, would you mind posting a public link to the file in this thread or sending to my PM so that I could test on my machine?
Just one thing to check here - can you make sure if Fusion uses the latest version of graphics card in the system?
You would please go to the [?] icon (help menu) and select "Graphic Diagnostics". Then you would see the information in the window as below.
Thank you.
