Construction Lines Moving Unexpectedly
The contruction lines are moved as defined by the dimension, as expected. However, notice that the lines have also randomly shifted along their perpendicualr axis. I have not seen this before. This should not be happening.
Hi @kevinwatts,
Thank you for posting in the forum! I was able to reproduce the behavior and reported it to the development team for further investigation. (the ticket ID is FUS-37840 just for your reference)
I deleted perpendicular constraints that were added automatically when drawing lines, and then I did not see the behavior so I assume this is something to do with the constraints.
Thank you for reporting the issue!
