Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Sketch: Construction Lines Moving Unexpectedly
1 REPLY 1
kevinwatts
444 Views, 1 Reply
  1. In the following Sketch, construction axis lines were placed and anchored.
  2. Four additional construction lines of the same length were then added aproximatly 1 inch eather side of the center axis.
  3. Each of the four construction lines were then selected along with their respective center axis line and their respective location from the center working axis was dimensioned to 3.75 inches.
The contruction lines are moved as defined by the dimension, as expected. However, notice that the lines have also randomly shifted along their perpendicualr axis. I have not seen this before. This should not be happening.
Note: Construction Lines prepared, with main working axis lines locked, before dimensioning.Note: Construction Lines prepared, with main working axis lines locked, before dimensioning.Note: Construcion Lines have shifted after dimensions added.Note: Construcion Lines have shifted after dimensions added.
1 REPLY 1
masa.minohara
in reply to: kevinwatts
Hi @kevinwatts,
Thank you for posting in the forum! I was able to reproduce the behavior and reported it to the development team for further investigation. (the ticket ID is FUS-37840 just for your reference)
I deleted perpendicular constraints that were added automatically when drawing lines, and then I did not see the behavior so I assume this is something to do with the constraints.
Thank you for reporting the issue!
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Technology Administrators
