I am doing a render but not all elements are rendering.
The screenshot below shows the element that is not rendering.
I also see the element in the render window. Below is the render where you can see the missing element.
A week ago there was no issues and it was rendering properly. I have not worked on the project since.
I further noticed that the same issue shows up when I render the subassembly:
Any help much appreciated.
Solved the issue!
The element that wasn't showing up had a "File is not available at the moment" error. I just downloaded the file and upload as a new version. Works fine now 🙂
