Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Render: not all elements are exporting
2 REPLIES 2
234 Views, 2 Replies
I am doing a render but not all elements are rendering.
The screenshot below shows the element that is not rendering.
I also see the element in the render window. Below is the render where you can see the missing element.
A week ago there was no issues and it was rendering properly. I have not worked on the project since.
I further noticed that the same issue shows up when I render the subassembly:
Any help much appreciated.
Tags (2)
Labels (2)
2 REPLIES 2
I further noticed that when rendering a sub assembly with that vanishing element the same issue occurs.
Solved the issue!
The element that wasn't showing up had a "File is not available at the moment" error. I just downloaded the file and upload as a new version. Works fine now 🙂
