unable to move/modify sketch points
Title says it all. Whenever I try to drag a point it gives me this error: "Some sketch curves cannot be converted to profile edges". The F3D file of the project is also provided
jeff_strater
The "curves cannot be converted to profile" error usually means that there are one or more degenerate curves in your sketch.  In this case, I found it here:
see the screencast below.  However, even with that error removed, I am unable to move anything in this sketch.  Will have to have the team dig into why that is.
Jeff Strater
Engineering Director
jeff_strater
did a bit more debugging on this.  I found that there are two curves that seem to be the source of the problem:
If I delete those and re-create them (sorry, I didn't re-create them correctly - you can do that), I can again move points in this sketch.  I'm having the dev team look into this, but until then, delete those two and re-create them, you should be OK.
Jeff Strater
Rohan.bongale
Thankyou for sharing the issue, we were able to reproduce this issue on our side, I have logged a bug and assigned it to the development team to get it fixed
