Fusion Support
Render Mesh Dark Spots
3 REPLIES 3
jp.scholz
523 Views, 3 Replies
I tried to render a OBJ File exported from Tinkercad. The preview looks fine but the finished rendering has a dark pattern in the back. I changed settings for shadows/lightning but it didn't change anything.
Can anyone help me resolve the issue?Thanks!
3 REPLIES 3
tallisb
in reply to: jp.scholz
JP-
It looks like your material is really shiny.  You might try rotating the light source a bit and re-render and see if that makes a difference.  It could be a reflection of the environment.
If not, do you mind sharing your model so we can try and reproduce?
Thank you-
Brad
Brad Tallis
Fusion 360 Technical Specialist
jp.scholz
in reply to: tallisb
Hi, I rotated the light source and also changed the material but it doesn't seem to make any diffrence. Only rotating the object itself changes the outcome of the rendering.
I attached the project file. Thank you for looking into the problem!
tallisb
Thank you for sharing the file.
I was able to recreate your issue if I rendered using the Render icon (the teapot), but if I rendered as an in-canvas render, it rendered correctly.
So, you can do an in-canvas render and then use "Capture Image" to save it locally on your machine.
The last thing you could do is to just re-create the cylinder part in Fusion 360.  After creating the cylinder part, turn off the mesh cylinder part and then render.
 Rendered In-CanvasRendered In-CanvasLocal Render after re-creating cylinder as a solid bodyLocal Render after re-creating cylinder as a solid body
Brad Tallis
