Is there a simple way of re-invoking the recent Fusion update process?
... as a corruption/mishandling happened in the last one.
Regards
MichaelT
Solved by RajkumarIlanchelian. Go to Solution.
Solved by jhackney1972. Go to Solution.
Open the Fusion Service Utility and run the Repair option.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Thank you, Mr RajkumarIlanchelian and Mr JHackney1972,
for the solution which seems to be in the plain sight and also so straightforward ....
that I accepted it as the legit answer to my problem ... even before actually checking it.
Well, ... it seems that the issue is a little bit more sneaky.
@MichaelT_123 Ok, let run the below:
Close Fusion
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
