Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Re-pulling the recent update
6 REPLIES 6
MichaelT_123
278 Views, 6 Replies
Is there a simple way of re-invoking  the recent Fusion update process?
... as a corruption/mishandling happened in the last one.
Regards
MichaelT
MichaelT
Tags (2)
6 REPLIES 6
jhackney1972
in reply to: MichaelT_123
Open the Fusion Service Utility and run the Repair option.
John Hackney, Retired
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Thank you, Mr RajkumarIlanchelian and Mr JHackney1972,
for the solution which seems to be in the plain sight and also so straightforward ....
that I accepted it as the legit answer to my problem ... even before actually checking it.
Well, ... it seems that the issue is a little bit more sneaky.
Running the Service Utility once wit Repair option  resulted in:
The code execution cannot proceed because adp_core-6_1.dll, Qt65vg.dll, ....
was not found. Reinstalling the program may fix this problem.
The Fusion and so the Service Utility could not run afterwards.
Installation from WEB was refused as the process recognized that I have the latest version already ... thus I ended up in the circular conundrum.
The log file generated by the first run of the Service Utility is attached.
Regards
MichaelT
MichaelT
@MichaelT_123 Ok, let run the below:
Close Fusion
  1. Make sure that Fusion installer is not running in task manager
  2. Go to Add/remove program and uninstall Fusion
  3. Go to C:\Users\user\AppData\Local\ DELETE folder Autodesk\
  4. Delete the Fusion shortcut you use to launch Fusion
  5. Download the installer again
  6. Now install again
    Please let me know if this solves the issue and it should solve the live update issue too.
Autodesk Fusion
Join Fusion Insider
Hi Mr RajkumarIlanchelian,
Even before reading your post ... I decided on the risky move.
As the FPatient was dead already and despite that I am not FDoctor, I have determined to perform on it a brutal spoon&fork surgery.
I did implant  _  at the front of ..\production and ..\meta folders in C:\Users\MichaelT\AppData\Local\Autodesk\webdeploy
In the second phase, I equipped myself with a coffee and nervously hit the Install Button in the tool downloaded from the WEB.
Before the third sip, the new installation was completed without a hitch ... then Fusion opened itself and blinked a couple of screens at me .... as if nothing had happened.
I happily blinked back, and now I am in the process of feeding the risen FPatient a healthy porridge of Python modules.
Fingers cross ... that the recovery will be fast&full.
Thank you for your help and assistance in this stressful situation.
Regards
MichaelT
MichaelT
Autodesk Fusion
Join Fusion Insider
