Fusion Support
Random line on drawings
4 REPLIES 4
575 Views, 4 Replies
I have some random lines that appear when I convert my project to a drawing. It seems to be in the area where I have added a different drawing to the same file. You cannot see them in the main model work environment but they do appear in the thumbnail pictures in the data panel and also when I create a drawing. Help please!
4 REPLIES 4
innovatenate
Hi @Anonymous! Welcome to the community!
When I've seen this in the past, it is usually a conflict with a specific hardware or graphics driver. If you haven't done so yet, try updating your graphics driver (assuming Windows OS). If that doesn't help, can you share more information about what graphics card you are using? If you're on Windows, you could share the dxdiag report.
  1. Launch %windir%\system32\dxdiag.exe
  2. Select Save All Information
  3. Please reply with the resulting *.TXT file attached
Let me know if you have any questions. I am happy to help!
Nathan Chandler
Principal Specialist
System Information
Time of this report: 10/24/2017, 17:56:41
Machine name: DAD-PC
Machine Id: {97660928-B4EA-446C-B739-ADA876DD0AF2}
Operating System: Windows 10 Pro 64-bit (10.0, Build 15063) (15063.rs2_release.170317-1834)
Language: English (Regional Setting: English)
System Manufacturer: HP-Pavilion
System Model: VG244AA-ABU p6235uk
BIOS: OS Date: 09/17/09 16:12:09 Ver: 5.06
Processor: Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz (4 CPUs), ~2.7GHz
Memory: 4096MB RAM
Available OS Memory: 4088MB RAM
Page File: 4805MB used, 3377MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.15063.0000 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce GT 220
Manufacturer: NVIDIA
Chip type: GeForce GT 220
DAC type: Integrated RAMDAC
Device Type: Full Device
Device Key: Enum\PCI\VEN_10DE&DEV_0A20&SUBSYS_19101462&REV_A2
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: 3016 MB
Dedicated Memory: 972 MB
Shared Memory: 2043 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: W2243
Monitor Id: GSM56FE
Native Mode: 1920 x 1080(p) (59.934Hz)
Output Type: HD15
Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll
Driver File Version: 21.21.0013.4201 (English)
Driver Version: 21.21.13.4201
DDI Version: 11.1
Feature Levels: 10_1,10_0,9_3,9_2,9_1
Driver Model: WDDM 1.2
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Applicable
Power P-states: Not Applicable
Driver Attributes: Final Retail
Driver Date/Size: 14/11/2016 01:00:00, 17722448 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: Unknown
Device Identifier: {D7B71E3E-4960-11CF-BB67-1D3918C2D835}
Vendor ID: 0x10DE
Device ID: 0x0A20
SubSys ID: 0x19101462
Revision ID: 0x00A2
Driver Strong Name: oem126.inf:0f066de3b8f6b746:Section024:21.21.13.4201:pci\ven_10de&dev_0a20&subsys_19101462
Rank Of Driver: 00DA0001
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
DXVA2 Modes: DXVA2_ModeMPEG2_IDCT DXVA2_ModeMPEG2_VLD DXVA2_ModeVC1_D2010 DXVA2_ModeVC1_VLD DXVA2_ModeVC1_IDCT DXVA2_ModeWMV9_IDCT DXVA2_ModeH264_VLD_Stereo_Progressive_NoFGT DXVA2_ModeH264_VLD_Stereo_NoFGT DXVA2_ModeH264_VLD_NoFGT DXVA2_ModeMPEG4pt2_VLD_Simple DXVA2_ModeMPEG4pt2_VLD_AdvSimple_NoGMC
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Supported
DXVA-HD: Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
MPO Caps: Not Supported
MPO Stretch: Not Supported
MPO Media Hints: Not Supported
MPO Formats: Not Supported
Sound Devices
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_103C2A90&REV_1002
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.7535 (English)
WHQL Logo'd: Yes
Date and Size: 16/06/2015 00:00:00, 4504320 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x3B34
| Matching Device ID: USB\ROOT_HUB20
| Service: usbhub
| Driver: usbhub.sys, 9/30/2017 06:45:54, 511896 bytes
| Driver: usbd.sys, 3/18/2017 21:56:35, 32160 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x8087, 0x0020
| | Matching Device ID: USB\Class_09
| | Service: usbhub
| +-+ USB Input Device
| | | Vendor/Product ID: 0x045E, 0x0752
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | Driver: hidusb.sys, 3/18/2017 21:56:35, 40960 bytes
| | | Driver: hidclass.sys, 3/18/2017 21:56:35, 180736 bytes
| | | Driver: hidparse.sys, 3/18/2017 21:56:35, 40960 bytes
| | +-+ Microsoft Wired Keyboard 400 (Mouse and Keyboard Center)
| | | | Matching Device ID: HID\VID_045E&PID_0752
| | | | Service: kbdhid
| | | | Driver: kbdhid.sys, 3/18/2017 21:56:35, 40448 bytes
| | | | Driver: kbdclass.sys, 3/18/2017 21:56:35, 64416 bytes
| +-+ Microsoft Hardware USB Mouse
| | | Vendor/Product ID: 0x045E, 0x00CB
| | | Matching Device ID: usb\vid_045e&pid_00cb
| | | Service: HidUsb
| | | Driver: coin99ip.dll, 1/2/2016 15:32:17, 466728 bytes
| | +-+ Microsoft USB Basic Optical Mouse v2.0 (Mouse and Keyboard Center)
| | | | Matching Device ID: HID\VID_045E&PID_00CB
| | | | Upper Filters: Point64
| | | | Service: mouhid
| | | | Driver: point64.sys, 3/19/2014 16:23:14, 50896 bytes
| | | | Driver: mouhid.sys, 3/18/2017 21:56:35, 33280 bytes
| | | | Driver: mouclass.sys, 3/18/2017 21:56:35, 60320 bytes
| | | | Driver: WdfCoInstaller01011.dll, 3/19/2014 16:23:16, 1795952 bytes
Gameport Devices
PS/2 Devices
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 28.0 GB
Total Space: 595.8 GB
File System: NTFS
Model: WDC WD6400AAKS-65A7B2
Drive: 😧
Free Space: 2.4 GB
Total Space: 14.2 GB
File System: NTFS
Drive: E:
Model: TSSTcorp CDDVDW TS-H653R
Driver: c:\windows\system32\drivers\cdrom.sys, 10.00.15063.0000 (English), 3/18/2017 21:56:25, 160256 bytes
System Devices
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_3B56&SUBSYS_2A90103C&REV_05\3&11583659&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 10.00.15063.0447 (English), 8/6/2017 22:29:06, 86528 bytes
Driver: C:\WINDOWS\system32\DRIVERS\drmk.sys, 10.00.15063.0000 (English), 3/18/2017 21:56:20, 97280 bytes
Driver: C:\WINDOWS\system32\DRIVERS\portcls.sys, 10.00.15063.0000 (English), 3/18/2017 21:56:20, 373248 bytes
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_2A90103C&REV_A5\3&11583659&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 10.00.15063.0000 (English), 3/18/2017 21:56:26, 353696 bytes
Device ID: PCI\VEN_10DE&DEV_0BE2&SUBSYS_19101462&REV_A1\4&33C0B30A&0&0118
Name: NVIDIA GeForce GT 220
Device ID: PCI\VEN_10DE&DEV_0A20&SUBSYS_19101462&REV_A2\4&33C0B30A&0&0018
Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 21.21.0013.4201 (English), 12/9/2016 14:24:56, 461376 bytes
Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 11/14/2016 05:30:58, 1238696 bytes
Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nvhdcwu.inf_amd64_b44eecc7dd617f66\NvCplSetupInt.exe, 1.00.0005.0000 (English), 12/9/2016 14:26:20, 83498768 bytes
Driver: C:\Program Files\NVIDIA Corporation\license.txt, 11/14/2016 05:30:58, 26629 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (English), 12/9/2016 14:25:08, 859320 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.4201 (English), 12/9/2016 14:26:32, 243264 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 11/14/2016 05:30:58, 56689 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.4201 (English), 12/9/2016 14:27:04, 354368 bytes
Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.4201 (English), 12/9/2016 14:33:50, 664640 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.00.0000.0000 (English), 12/9/2016 14:35:48, 76864 bytes
Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.00.0000.0000 (English), 12/9/2016 14:35:48, 91832 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nvlddmkm.sys, 21.21.0013.4201 (English), 12/9/2016 14:15:36, 12914360 bytes
Driver: C:\WINDOWS\system32\NvFBC64.dll, 6.14.0013.4201 (English), 12/9/2016 14:26:42, 919104 bytes
Driver: C:\WINDOWS\system32\NvIFR64.dll, 6.14.0013.4201 (English), 12/9/2016 14:27:26, 960576 bytes
Driver: C:\WINDOWS\system32\nvapi64.dll, 21.21.0013.4201 (English), 12/9/2016 14:14:34, 3245408 bytes
Driver: C:\WINDOWS\system32\nvcompiler.dll, 8.17.0013.4201 (English), 12/9/2016 14:25:38, 23009344 bytes
Driver: C:\WINDOWS\system32\nvcuda.dll, 8.17.0013.4201 (English), 12/9/2016 14:14:46, 13957376 bytes
Driver: C:\WINDOWS\system32\nvcuvid.dll, 7.17.0013.4201 (English), 12/9/2016 14:26:32, 4262584 bytes
Driver: C:\WINDOWS\system32\nvd3dumx.dll, 21.21.0013.4201 (English), 12/9/2016 14:14:56, 17722448 bytes
Driver: C:\WINDOWS\system32\nvinfo.pb, 11/14/2016 05:30:58, 26157 bytes
Driver: C:\WINDOWS\system32\nvoglv64.dll, 21.21.0013.4201 (English), 12/9/2016 14:34:26, 31532728 bytes
Driver: C:\WINDOWS\system32\nvopencl.dll, 8.17.0013.4201 (English), 12/9/2016 14:15:10, 14046888 bytes
Driver: C:\WINDOWS\system32\nvwgf2umx.dll, 21.21.0013.4201 (English), 12/9/2016 14:15:38, 18806712 bytes
Driver: C:\WINDOWS\SysWow64\NvFBC.dll, 6.14.0013.4201 (English), 12/9/2016 14:26:42, 885824 bytes
Driver: C:\WINDOWS\SysWow64\NvIFR.dll, 6.14.0013.4201 (English), 12/9/2016 14:27:22, 923200 bytes
Driver: C:\WINDOWS\SysWow64\nvapi.dll, 21.21.0013.4201 (English), 12/9/2016 14:14:30, 2856736 bytes
Driver: C:\WINDOWS\SysWow64\nvcompiler.dll, 8.17.0013.4201 (English), 12/9/2016 14:25:42, 15310400 bytes
Driver: C:\WINDOWS\SysWow64\nvcuda.dll, 8.17.0013.4201 (English), 12/9/2016 14:14:42, 11315752 bytes
Driver: C:\WINDOWS\SysWow64\nvcuvid.dll, 7.17.0013.4201 (English), 12/9/2016 14:26:28, 4004536 bytes
Driver: C:\WINDOWS\SysWow64\nvd3dum.dll, 21.21.0013.4201 (English), 12/9/2016 14:14:50, 14634032 bytes
Driver: C:\WINDOWS\SysWow64\nvoglv32.dll, 21.21.0013.4201 (English), 12/9/2016 14:34:06, 24217784 bytes
Driver: C:\WINDOWS\SysWow64\nvopencl.dll, 8.17.0013.4201 (English), 12/9/2016 14:15:06, 11378680 bytes
Driver: C:\WINDOWS\SysWow64\nvwgf2um.dll, 21.21.0013.4201 (English), 12/9/2016 14:15:20, 16279296 bytes
Driver: C:\WINDOWS\system32\nvdispco6434201.dll, 2.00.0041.0004 (English), 12/9/2016 14:26:36, 1917640 bytes
Driver: C:\WINDOWS\system32\nvdispgenco6434201.dll, 2.00.0020.0002 (English), 12/9/2016 14:26:38, 1566920 bytes
Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B34
Device ID: PCI\VEN_8086&DEV_3B34&SUBSYS_2A90103C&REV_05\3&11583659&0&E8
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 10.00.15063.0000 (English), 3/18/2017 21:56:35, 98200 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 10.00.15063.0000 (English), 3/18/2017 21:56:35, 466336 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 10.00.15063.0674 (English), 9/30/2017 06:45:54, 511896 bytes
Device ID: PCI\VEN_8086&DEV_D155&SUBSYS_0090003C&REV_11\3&11583659&0&40
Driver: n/a
Device ID: PCI\VEN_8086&DEV_D158&SUBSYS_0090003C&REV_11\3&11583659&0&43
Driver: n/a
Device ID: PCI\VEN_8086&DEV_D150&SUBSYS_0090003C&REV_11\3&11583659&0&80
Driver: n/a
Device ID: PCI\VEN_8086&DEV_D131&SUBSYS_2A90103C&REV_11\3&11583659&0&00
Driver: n/a
Device ID: PCI\VEN_8086&DEV_3B46&SUBSYS_2A90103C&REV_05\3&11583659&0&E2
Device ID: PCI\VEN_8086&DEV_D156&SUBSYS_0090003C&REV_11\3&11583659&0&41
Driver: n/a
Name: VIA 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_1106&DEV_3403&SUBSYS_2A90103C&REV_00\4&109D517A&0&00E2
Driver: C:\WINDOWS\system32\DRIVERS\1394ohci.sys, 10.00.15063.0000 (English), 3/18/2017 21:56:25, 238080 bytes
Name: LPC Controller
Device ID: PCI\VEN_8086&DEV_3B02&SUBSYS_2A90103C&REV_05\3&11583659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 10.00.15063.0000 (English), 3/18/2017 21:56:26, 19352 bytes
Name: Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
Device ID: PCI\VEN_8086&DEV_2822&SUBSYS_2A90103C&REV_05\3&11583659&0&FA
Driver: C:\WINDOWS\system32\DRIVERS\iaStorAV.sys, 13.02.0000.1022 (English), 3/18/2017 21:56:26, 673184 bytes
Name: Virtualization Engine Controller
Device ID: PCI\VEN_8086&DEV_3B30&SUBSYS_2A90103C&REV_05\3&11583659&0&FB
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced Host Controller - 3B3C
Device ID: PCI\VEN_8086&DEV_3B3C&SUBSYS_2A90103C&REV_05\3&11583659&0&D0
Device ID: PCI\VEN_8086&DEV_D151&SUBSYS_0090003C&REV_11\3&11583659&0&81
Driver: n/a
Device ID: PCI\VEN_8086&DEV_D157&SUBSYS_0090003C&REV_11\3&11583659&0&42
Driver: n/a
Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_2A90103C&REV_03\4&1D638FB1&0&00E0
Driver: C:\WINDOWS\system32\DRIVERS\rt640x64.sys, 9.01.0406.2015 (English), 3/18/2017 21:56:26, 604160 bytes
Device ID: PCI\VEN_8086&DEV_D138&SUBSYS_2A90103C&REV_11\3&11583659&0&18
Device ID: PCI\VEN_8086&DEV_3B42&SUBSYS_2A90103C&REV_05\3&11583659&0&E0
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.15063.0000
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.15063.0000
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.15063.0000
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.15063.0000
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.15063.0000
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.15063.0000
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.15063.0000
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.15063.0000
MS ATC Screen Decoder 1,0x00600800,1,1,scdec.dll,15.00.4703.1000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.15063.0000
DV Muxer,0x00400000,0,0,qdv.dll,10.00.15063.0000
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.15063.0674
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.15063.0502
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.15063.0674
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.15063.0674
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.15063.0000
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.15063.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.15063.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.15063.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.15063.0674
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.15063.0674
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.15063.0674
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.15063.0000
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.15063.0000
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.15063.0000
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.15063.0000
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.15063.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.15063.0674
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.15063.0674
Sonitus:fx SurroundComp,0x00200000,1,1,SonitusFXSurroundCompressor.dll,3.07.0005.0018
DV Splitter,0x00600000,1,2,qdv.dll,10.00.15063.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.15063.0674
Cakewalk TTS-1,0x00200000,1,1,TTS-1.dll,1.00.0002.0000
Haali Media Splitter,0x00800001,0,1,splitter.x64.ax,1.13.0138.0014
Haali Media Splitter (AR),0x00400000,1,1,splitter.x64.ax,1.13.0138.0014
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.15063.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.15063.0674
Video Renderer,0x00800001,1,0,quartz.dll,10.00.15063.0674
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.15063.0000
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.15063.0674
Video Renderer,0x00400000,1,0,quartz.dll,10.00.15063.0674
Haali Video Renderer,0x00200000,1,0,dxr.x64.dll,
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.15063.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.15063.0502
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.15063.0000
Haali Simple Media Splitter,0x00200000,0,1,splitter.x64.ax,1.13.0138.0014
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.15063.0000
Overlay Mixer2,0x00200000,1,1,,
Haali Matroska Muxer,0x00200000,1,0,splitter.x64.ax,1.13.0138.0014
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.15063.0000
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.15063.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.15063.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.15063.0000
Cakewalk Analyst,0x00200000,1,1,Analyst.dll,1.00.0000.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.15063.0000
Null Renderer,0x00200000,1,0,qedit.dll,10.00.15063.0000
Sonitus:fx Equalizer,0x00200000,1,1,SonitusFXEqualizer.dll,3.07.0005.0018
Sonitus:fx Modulator,0x00200000,1,1,SonitusFXModulator.dll,3.03.0005.0000
Sonitus:fx Reverb,0x00200000,1,1,SonitusFXReverb.dll,3.07.0005.0018
Sonitus:fx Phase,0x00200000,1,1,SonitusFXPhase.dll,3.07.0005.0018
Sonitus:fx Surround,0x00200000,1,1,SonitusFXSurround.dll,3.07.0005.0018
Sonitus:fx Wahwah,0x00200000,1,1,SonitusFXWahwah.dll,3.07.0005.0018
Sonitus:fx Compressor,0x00200000,1,1,SonitusFXCompressor.dll,3.07.0005.0018
Sonitus:fx Multiband,0x00200000,1,1,SonitusFXMultiband.dll,3.07.0005.0018
Sonitus:fx Delay,0x00200000,1,1,SonitusFXDelay.dll,3.07.0005.0018
Sonitus:fx Gate,0x00200000,1,1,SonitusFXGate.dll,3.07.0005.0018
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.15063.0000
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.15063.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.15063.0000
Smart Tee,0x00200000,1,2,qcap.dll,10.00.15063.0000
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.15063.0674
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.15063.0674
Wave Parser,0x00400000,1,1,quartz.dll,10.00.15063.0674
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.15063.0674
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.15063.0674
File stream renderer,0x00400000,1,1,quartz.dll,10.00.15063.0674
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.15063.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.15063.0000
AVI Mux,0x00200000,1,0,qcap.dll,10.00.15063.0000
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.15063.0674
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.15063.0674
File Source (URL),0x00400000,0,1,quartz.dll,10.00.15063.0674
Roland GrooveSynth,0x00200000,1,1,P5antom.dll,1.01.0000.0003
Haali Video Sink,0x00200000,1,0,splitter.x64.ax,1.13.0138.0014
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.15063.0000
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.15063.0000
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.15063.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.15063.0674
Cakewalk HF Exciter,0x00200000,1,1,hfexciter.dll,2.00.0001.0046
Cakewalk Time/Pitch Stretch 2,0x00200000,1,1,Stretch.ax,17.07.0003.0018
Cakewalk Classic Phaser,0x00200000,1,1,classicphaser.dll,2.00.0001.0046
Cakewalk Tempo Delay,0x00200000,1,1,tempodelay.dll,2.00.0001.0046
Cakewalk Compressor/Gate,0x00200000,1,1,compgate.dll,2.00.0001.0046
Cakewalk Amp Sim,0x00200000,1,1,AmpSim.Ax,17.05.0002.0306
Cakewalk Modfilter,0x00200000,1,1,modfilter.dll,2.00.0001.0046
Cakewalk Pitch Shifter,0x00200000,1,1,Pitch.Ax,17.05.0002.0306
Cakewalk FX2 Tape Sim,0x00200000,1,1,TapeSim.Ax,17.05.0002.0306
Cakewalk AliasFactor,0x00200000,1,1,Aliasfactor.dll,2.00.0001.0046
Cakewalk Multivoice Chorus/Flanger,0x00200000,1,1,multivoicechorusflanger.dll,2.00.0001.0047
GroovePlayer,0x00200000,1,1,GroovePlayer.dll,2.00.0000.0002
Cakewalk Para-Q,0x00200000,1,1,paraq.dll,2.00.0001.0046
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.15063.0000
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.15063.0000
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.15063.0000
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.15063.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.15063.0674
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.15063.0000
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.15063.0000
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.15063.0674
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.15063.0674
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.15063.0674
DV Audio -- NTSC,0x00200000,1,1,quartz.dll,10.00.15063.0674
DV Audio -- PAL,0x00200000,1,1,quartz.dll,10.00.15063.0674
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.15063.0674
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.15063.0674
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.15063.0674
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.15063.0000
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.15063.0000
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.15063.0000
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.15063.0674
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.15063.0674
WDM Streaming Capture Devices:
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
{17CCA71B-ECD7-11D0-B908-00A0C9223196},0x00200000,2,2,ksproxy.ax,10.00.15063.0000
WDM Streaming Rendering Devices:
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
Realtek HD Audio rear output,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
Realtek HD Audio front output,0x00200000,1,1,ksproxy.ax,10.00.15063.0000
{17CCA71B-ECD7-11D0-B908-00A0C9223196},0x00200000,1,1,ksproxy.ax,10.00.15063.0000
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.15063.0000
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.15063.0000
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.15063.0000
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.15063.0000
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.15063.0000
Video Capture Sources:
Corel Camera Plug-in,0x00600000,0,1,,
CorelScreenCapture,0x00600000,0,1,,
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.15063.0000
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.15063.0000
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.15063.0000
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.15063.0000
PTFilter,0x00200000,0,0,EncDec.dll,10.00.15063.0000
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.15063.0000
WDM Streaming Communication Transforms:
Audio Renderers:
Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.15063.0674
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.15063.0674
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.15063.0674
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,10.00.15063.0674
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
Video Decoders:
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.15063.0000
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.15063.0000
Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}, 0x1, hevcdecoder.dll, 10.00.15063.0000
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.15063.0000
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.15063.0000
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.15063.0000
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.15063.0000
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.15063.0138
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.15063.0000
Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}, 0x1, MSVP9DEC.dll, 10.00.15063.0000
MS ATC Screen Decoder 1, {F1931D8E-51D3-496F-BE8A-3D08AEE9C9DB}, 0x1, scdec.dll, 15.00.4703.1000
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.15063.0000
Video Encoders:
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.15063.0000
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.15063.0000
Microsoft MF VPX Encoder Transform, {AEB6C755-2546-4881-82CC-E15AE5EBFF3D}, 0x1, MSVPXENC.dll, 10.00.15063.0296
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.15063.0000
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.15063.0000
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.15063.0000
H265 Encoder MFT, {F2F84074-8BCA-40BD-9159-E880F673DD3B}, 0x1, mfh265enc.dll, 10.00.15063.0000
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.15063.0000
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.15063.0000
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.15063.0250
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.15063.0000
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.15063.0000
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.15063.0608
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.15063.0502
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.15063.0000
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.15063.0000
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.15063.0447
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.15063.0608
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.15063.0608
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.15063.0000
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.15063.0000
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.15063.0000
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.15063.0447
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.15063.0000
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.15063.0608
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.15063.0608
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.15063.0000
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.15063.0000
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.15063.0608
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.15063.0000
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.15063.0000
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.15063.0000
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.15063.0608
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.15063.0000
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.15063.0000
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.15063.0000
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.15063.0000
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.15063.0000
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.15063.0000
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.15063.0000
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.15063.0000
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.15063.0000
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.15063.0000
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.15063.0000
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.15063.0000
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 0
EnableEncoders = 1
EnableVideoProcessors = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
, , [, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
, , [, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
{43564548-0000-0010-8000-00AA00389B71}, Microsoft H265 Video Decoder MFT, {420A51A3-D605-430C-B4FC-45274FA6C562}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{30395056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
{30385056-0000-0010-8000-00AA00389B71}, Microsoft WebM MF VP8 Decoder Transform, {E3AAF548-C9A4-4C6E-234D-5ADA374B0000}
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket , type 0
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: WerFault.exe
P2: 10.0.15063.608
P3: 14bf4eac
P4: 1992
P5: 134217729
P6:
P7:
P8:
P9:
P10:
+++ WER1 +++:
Fault bucket 120849793225, type 4
Event Name: APPCRASH
Cab Id: 0
Problem signature:
P1: Fusion360.exe
P2: 3481.2.0.0
P3: 59d67c84
P4: NsBase10.dll
P5: 3481.2.0.0
P6: 59d6782c
P7: c0000005
P8: 000000000030dc58
P9:
P10:
+++ WER2 +++:
Fault bucket 129567789582, type 5
Event Name: RADAR_PRE_LEAK_64
Cab Id: 0
Problem signature:
P1: chrome.exe
P2: 61.0.3163.100
P3: 10.0.15063.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER3 +++:
Fault bucket 129553877882, type 5
Event Name: RADAR_PRE_LEAK_WOW64
Cab Id: 0
Problem signature:
P1: iexplore.exe
P2: 11.0.15063.608
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER4 +++:
Fault bucket 116441551016, type 5
Event Name: BEX64
Cab Id: 0
Problem signature:
P1: svchost.exe
P2: 10.0.15063.0
P3: 02799ef5
P4: ntdll.dll
P5: 10.0.15063.608
P6: 8274fd8b
P7: 00000000000aa020
P8: c0000409
P9: 000000000000000a
P10:
+++ WER5 +++:
Event Name: BEX64
Cab Id: 0
Problem signature:
P1: svchost.exe
P2: 10.0.15063.0
P3: 02799ef5
P4: ntdll.dll
P5: 10.0.15063.608
P6: 8274fd8b
P8: c0000409
P10:
+++ WER6 +++:
Fault bucket 129574568969, type 5
Cab Id: 0
Problem signature:
P1: AcCoreConsole.exe
P2: 22.0.48.351
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER7 +++:
Fault bucket 128046772557, type 5
Event Name: WindowsUpdateFailure3
Cab Id: 0
Problem signature:
P1: 10.0.15063.674
P2: 8024001e
P3: 7BE142C5-9DD7-4331-B949-0F60CF3CF242
P4: Install
P5: 200
P6: 0
P7: 8024000b
P8: UpdateOrchestrator
P9: {7971F918-A847-4430-9279-4A52D1EFE18D}
P10: 0
+++ WER8 +++:
Fault bucket 129584512068, type 5
Cab Id: 0
Problem signature:
P1: explorer.exe
P2: 10.0.15063.674
P3: d8364343
P4: dd33
P5: 134217728
P6:
P7:
P8:
P9:
P10:
+++ WER9 +++:
Fault bucket 129575321204, type 5
Cab Id: 0
Problem signature:
P1: OUTLOOK.EXE
P2: 15.0.4963.1000
P3: 5992bb29
P4: 0eb9
P5: 134217728
P6:
P7:
P8:
P9:
P10:
in reply to: innovatenate
Hi, thanks for prompt reply. Have checked and my card (GeForce GT220) has the current  driver. Requested file attached.
Regards
Donald
innovatenate
Thanks!
Looking at the system, you have 4 GB of RAM and some portion of the graphics is shared. It could be that the graphics artifacts are appearing as the system runs low on system memory. In this case adding some more RAM to the computer might be a worthwhile investment. RAM is fairly inexpensive.
Otherwise, another options may be to set the graphics driver Preferences to Direct X 9.
I'd also be curious if the limit effects to optimize performance... setting in the Help > Graphics Diagnostics dialog was any help as well.  See this link for more detail.
I hope this helps!
Nathan Chandler
