Fusion Support
New tool library bug
4 REPLIES 4
664 Views, 4 Replies
I believe this occurred after the latest update, even if I can't be 100% sure: whenever I create a drill endmill or I edit an existing one any shaft layer I set gets lost on tool save.
To reproduce, you just have to create a drill tool with a shaft of 3.175mm and a diameter of 1.0mm, then switch to Shaft tab and create a new shaft layer.
Save the tool to see any shaft layer info has been simply lost. Reopen the tool in edit mode to confirm any shaft layer has been lost and adding a new shaft layer just defaults to 10mm between 10mm and 10mm.
I've tried many alternatives and I can confirm this was once working perfectly as I have drilling bits in my tool library perfectly defined.
The issue impacts center drill tools as well.
Tags (1)
4 REPLIES 4
masa.minohara
Hi @Anonymous,
Thank you for reporting the issue! I was able to reproduce the issue and I think this is a bug. I've logged the issue with the development team for further investigation. (the ticket ID is CAM-8647 just for your reference)
I apologize for the inconvenience.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
in reply to: masa.minohara
Hi @masa.minohara,
I'm really happy to help shape a great tool: reporting defects is the bare minimum we, community users, should do to pay back for the great software you give us for free.
Thanks a lot.
peter.pretsch
Thanks @Anonymous,
this has been fixed and will be availble with the late November update.
Kind regards,
Peter
Peter V. Pretsch
SW Development Manager
Astonishing!
