O/S: Mac OSX 12.4
Every time that I start the Fusion 360 application I am promoted to log in.
I have tried:
Immediately after logging in this is the state of LoginState.xml which isn't what I would expect:
<?xml version='1.0'?>
<WebServices LastSavedBy="AdSSO-v2">
<Settings LogoutDate="" SuppressLoginReminder="False" CurrentServer="ProductionServer" LastLoginReminderDate=""/>
</WebServices>
Two things that are possibly note worthy are:
I would very much appreciate any suggestions on how to stop the requirement of needing to log in every time I start the application.
Solved by rowan.l.smith. Go to Solution.
Hi @rowan.l.smith ,
This article may help you to troubleshoot the issue.
Autodesk software asks to Sign in every time it is launched, every few days, or at every reboot
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! "Like" is always welcomed.
Sunil Patil,
Technical support specialist Fusion360,
Autodesk, Inc.
