Announcements
Installation of fusion 360
sileny.maik
Community Visitor
sileny.maik
Community Visitor
Community Visitor
Good day. I installed on a new disk fusion 360. Everything worked fine. The next day the fusion didn't work anymore. Why is fusion installed in the appdata folder and not in the programfiles?? I can't reinstall everything before every time I use fision.
jhackney1972
You should not have to install but once.  Please attach your log files.  If you do not know how to gather them up, take a look at this web page.  Once you have them add them to a zip file and use the attachment section below.  Using these log files will help determine why your are having an issue running the application.
To answer your question.  Fusion 360 is a cloud base application and also installs using a web based streamer.  It installs to your Appdata folders because it of this, being installed as per your profile.  Doing this you can get automatic updates as they are released.  This is viewed by some as a curse, by others as a great feature, that will be up to you decide.
John Hackney, Retired
