Fusion Support
Nothing happens when opening F360 :(
26 REPLIES 26
Message 1 of 27
joey.wulf95
717 Views, 26 Replies
Hello Everyone,
I am writing in here because I am completely desperate.
Unfortunately, since a few days nothing happens when I want to open F360. As soon as I click the .exe it just does not do anything.
I would claim that I have already tried everything imaginable.
I have done all the steps that are in this article:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Nothing-happens-wh...
After that it still did not work and I wrote to the support. The first suggestion from them was to create a new admin user and reinstall there. Second idea was to run in compatibility mode. Both did not help.
Then I thought that the last option is to reinstall Windows. I did that. Did not help.
And to make matters worse, now I don't get a message from support.
Does anyone here have any ideas?
Thanks a lot
Jonathan
26 REPLIES 26
Message 21 of 27
joey.wulf95
in reply to: joey.wulf95
  There are so many entries in the process monitor. Are these Screenshots helpful?
Message 22 of 27
Yes, this is exactly what the process monitor does. Now there will be an option to roll this up as a log file and zip it and send.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 23 of 27
Ah ok, it worked. I uploaded the file to wetransfer because it is 600 MB:
https://we.tl/t-3Dt5SCGTYe
Message 24 of 27
@joey.wulf95 Thank you for the logs. This may take a while for me to reply back as I do have to consult with our engineering team on what could be happening as they take a look at the logs. Will report back here.
Autodesk Fusion
Join Fusion Insider
Message 25 of 27
Hi Rajkumar,
was it already possible to find out something with the logs?
KR
Jonathan
Message 26 of 27
Hi Rajkumar,
look at this beauty:
The Problem was that my graphics card was not up to date... sometimes it can be so simple...
Thanks for your support!!!
KR
Jonathan
Message 27 of 27
Glad this is working now. Graphics card update was one of the first suggestions we had while this thread started. It’s always good to keep the graphics drivers up to date.
Autodesk Fusion
Join Fusion Insider
Technology Administrators
