Fusion Support
clicking "Share link" bricks fusion360
1 REPLY 1
phil9FLTF
74 Views, 1 Reply
When I click "Share link" on a file it greys out the entire program shows a webpage that says "Your file couldn't be accessed" and there is nothing you can do except force close Fusion360
1 REPLY 1
@phil9FLTF
1.Is this happening only on this particular design on any design on this machine?
2. If you login to Fusion team - https://login.autodesk360.com/login and do the exact same workflow, it is failing in there as well?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
