Hello Everyone,
I am writing in here because I am completely desperate.
Unfortunately, since a few days nothing happens when I want to open F360. As soon as I click the .exe it just does not do anything.
I would claim that I have already tried everything imaginable.
I have done all the steps that are in this article:
After that it still did not work and I wrote to the support. The first suggestion from them was to create a new admin user and reinstall there. Second idea was to run in compatibility mode. Both did not help.
Then I thought that the last option is to reinstall Windows. I did that. Did not help.
And to make matters worse, now I don't get a message from support.
Does anyone here have any ideas?
Thanks a lot
Jonathan
There are so many entries in the process monitor. Are these Screenshots helpful?
Yes, this is exactly what the process monitor does. Now there will be an option to roll this up as a log file and zip it and send.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
@joey.wulf95 Thank you for the logs. This may take a while for me to reply back as I do have to consult with our engineering team on what could be happening as they take a look at the logs. Will report back here.
Autodesk Fusion
Join Fusion Insider
Hi Rajkumar,
was it already possible to find out something with the logs?
KR
Jonathan
Hi Rajkumar,
look at this beauty:
The Problem was that my graphics card was not up to date... sometimes it can be so simple...
Thanks for your support!!!
KR
Jonathan
Glad this is working now. Graphics card update was one of the first suggestions we had while this thread started. It’s always good to keep the graphics drivers up to date.
Autodesk Fusion
Join Fusion Insider
