Is there a tool to create the bowl shape in between the two bodies like the highlighted surface in the picture shown? I tried loft but it just made it go inward, is there a way to make the loft curved? Is there a way to perform a fillet between the two bodies? I tried but I got an error.
Looks to me that you should have 3 cylinders stacked (Revolved or Extruded)
then add 4 fillets to make the rounded edges.
Loft will not do hollow or wall profiles in one feature, make the solid then a second loft for an internal cut. Or sometime a Shell will replace the second Loft.
Fillets work on a body crease, will not join 2 bodies, must be on the same body.
Might help…..
