Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
No way to launch Fusion 360 for MacOS
11 REPLIES 11
Message 1 of 12
siriusphil
604 Views, 11 Replies
Downloaded Fusion 360 MacOS yesterday, it launched and played with it.  Today, I realized that there is no Fusion app in the Applications folder, no launch icon on the desktop, no launch icon in the dock.  How am I supposed to launch Fusion 360?  This is pretty odd for a Mac app!
11 REPLIES 11
Message 2 of 12
@siriusphil @Fusion 360 is not installed in applications. Look in the launchpad and you should see the launch icon. Once it is launched you can keep the icon in the dock or choose to keep a short cut to your choice.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 12
If you keep a dock icon or otherwise make a shortcut to the application, it will break updates. New versions of Fusion 360 will be downloaded but they won't be launched because you will have a shortcut to the out-of-date executable.
Message 4 of 12
@lkerby
1. Go to /Users/YOUR USER ID/Applications
2. In here you will see Fusion 360
3. Create your short cut from here
Now on any number of updates, the icons will still and work.
Autodesk Fusion
Join Fusion Insider
Message 5 of 12
Thank you, I didn't realize this was fixed.
Message 6 of 12
lkerby
in reply to: siriusphil
Unfortunately this still does not behave as expected. Clicking the dock icon will launch multiple instances of Fusion 360 instead of bringing the application to the foreground.
Message 7 of 12
@lkerby Is this your workflow?
1. You created a shortcut using the Application folder I called out aboe
2. Ran Fusion 360 took and update
3. now if you launch Fusion you get multiple instances of Fusion?
Autodesk Fusion
Join Fusion Insider
Message 8 of 12
lkerby
Sorry, I have not been able to recreate this consistently. But yes, this behavior does occur for me on occasion. I have a shortcut in my dock pointed to the executable in said path. Typically clicking it will bring the already-open instance to the foreground. This morning, clicking on it launched a new instance that crashed immediately.
Message 9 of 12
lkerby
in reply to: lkerby
Seems to be related to the recent update. After closing out one instance and force-quitting the other, the shortcut began launching the Service Utility. After starting the application from the service utility, which took much longer than usual, the behavior is back to normal.
Message 10 of 12
@lkerby
"the behavior is back to normal."
Does this mean you are able to use the short cut you created and it now rightly launches one instance? (Also, you do not have to use the service utility to launch Fusion)
Autodesk Fusion
Join Fusion Insider
Message 11 of 12
Yes, the shortcut now works as expected again. It will launch the application or bring the running instance to the foreground. I believe this occasion, and my previous experience of this issue are related to the update procedure.
Message 12 of 12
I had the same issue after the latest update. Application crashed (reports generated for Apple and Autodesk), then brought up Service Utility. Once launched from that (after a wait) it works as normal again.
Olivewoodturning
Tags (1)
Technology Administrators
