myhub.autodesk.com tells me:
You don't have required permissions to perform this operation.
I can't see any of my files online. I'd like to organize my files and move them across projects. Seems quite a basic need, am I missing something obvious? I can't move the files in Fusion from project to project either. What is going on?
If you're working with distributed designs you can't move a linked design to another folder with the personal hub. Is that likely to be the problem you're having? You can only move linked designs to different folders using a team hub. You might want to update to a team hub as there are a few benefits like this with a team hub even if you're a single user.
Mark Hughes
Owner, Hughes Tooling
