This has come up several times. Sometimes the problem is the dialog is off screen so Alt+Space then M then an arrow key will make it jump to the mouse pointer but not this time! If the dialog was just hidden you would not be able to click on a button and have the command run, try this start insert DXF pick a plane and you'll get the open file dialog, now try clicking a button on the main toolbar and all that happens is the open dialog border flashes. If I do the same on my PC after picking the plane no dialog appears and I can just click any button and it runs so there can't be a dialog running.
I can't make a screencast as it doesn't work on my Windows 7 PC. Dialogs were working a week ago or so, maybe one of the recent updates caused this.
I've tried open, insert DXF, insert Mesh etc. and I'm not getting any of the windows file dialogs, I was able to get a dialog from the CAM workspace while posting a program but when I tried to use Open from the file dialog Fusion ended up in an unstable state and crashed.
Mark
Mark Hughes
Owner, Hughes Tooling
Solved by matt.pooley. Go to Solution.
In one of your options files (%APPDATA%\Autodesk\Neutron Platform\Options\NMachineSpecificOptions.xml) there will be a setting called 'LastDirectoryOptionId', and it might be pointing to a location that is no longer valid. If you delete the line that includes this setting and save the file, it may resolve your issue. (Note : Will need to restart Fusion after saving this options file)
Thanks, the issue appears to be related to a thumb drive I was using to transfer DXF files to a CNC workstation and when the thumb drive was not inserted in my machine I was unable to open any dialog boxes in Fusion. Inserting the thumb drive and restarting Fusion solved the problem. Going forward I am not going to save directly from Fusion to the thumb drive, I will save to the local drive and copy to the thumb drive instead.
I just had the same problem in Aug. 2021
your solution helped:
last I saved a file to a NAS (network attached storage) and after I mounted it again fusion worked normal again.
I also reinstalled Fustion and restarted my PC several times before that which did not help.
on Win10
Was also having this problem, exported a file to a drive path that doesn't exist anymore and the dialogue wouldn't display and I could no longer right-click to export as mesh again. Upon closing the file and reopening Fusion would crash. The fix @matt.pooley recommended worked. After deleting the line "LastDirectoryOptionID" and restarting Fusion it's working fine now. Kinda ridiculous this problem has been going on for years...
Path: %APPDATA%\Autodesk\Neutron Platform\Options\NMachineSpecificOptions.xml
Specfic line: <LastDirectoryOptionId UserName="LastDirectoryOptionId" Value=""/>
This is still not fixed. I reinstalled my server en after that I cannot open file from my comuter
Hi @infoLMLR6 ,
Is the workaround mentioned in this thread able to get your open dialogs working again ? If not, I can work with you to find a solution that gets you up and running.
If it does work, then the next area I'd like to understand is exactly what changed in your environment, what we've found with this problem is that each type of 'directory unavailable' scenario requires specific work and error handling, and ideally we'd be able to reproduce the situation you ended up in so we can investigate behaviors and solve.
Some examples of scenarios that we've previously heard about
- Removal of USB drive
- Samba / NFS Share errors
- Folder deletion
Matt
Chiming in here to confirm this was my issue - a password-protected network drive was my default save location, but I had disconnected it previously so it couldn't access it. Reconnecting solved the problem.
I had the same issue in that the LastDirectoryOptionId was a network share which had a different username/password than the currently logged in user. When trying to insert a DXF, I would click on the folder and it would act like nothing happened.
The fix was to access the share first from Windows Explorer to force a network login. Once the share was accessible from Windows Explorer, Fusion had no problem after that.
