Hey folks, I am very new to Fusion 360 but I have run into a couple problems that I cannot seem to correct.
Whenever I create a design for my CNC, I then go to 'Manufacture' and go through the process of setting up the cutting sequence etc at which point everything looks good in Fusion 360.
I then post the GCode as a .tap file for use with my CNC machine, only to find out when I run the gcode on my CNC the Z Axis Zero Point has been auto adjusted, resulting in the cutting process taking place around 10mm+ above the surface of the stock material.
For instance:
I load up the .tap file into Mach3, set all my Zero points on the machine, press 'Start' and the machine raises the Z axis to +15 (clearance5+Retract5+Feed Height5), starts the spindle and moves to X-Y entry points, the Z axis begins to lower into position, but then stops and it begins the cutting process at Z+10 instead of dropping down to Z-1.
When I test the GCode in a CNC Simulator (CAMotics) everything looks to be good. It's only when I run the GCode on my CNC that the problem happens.
The other program I use for CNC designs (Carbide Create) does not have this issue, however it's a lot more difficult to generate 3D models / paths.
I have included both the .tap / .dxf files for inspection if anyone has the time to assist. Would be great to know if I am doing something wrong or not.
