I am having trouble saving a local tool library... I have the proper folder and path according to other help posts...whenever I try to save I get this message...why is it trying to put it in this weird directory (which I do not have)
Hi @leversole,
Thank you for posting in the forum! That is a known issue and a fix will be released sometime soon. I apologize for the inconvenience.
In the meantime, could you try NOT changing the name of new tool libraries when creating, and keep the names as the default and check if they can be saved? (e.g. New Library 1, New Library 2)
Hi @leversole,
Will do...Thank You
Will do...Thank You
Thank you for the workaround, it work.
