Fusion Support
Fusion 360 crashing repeatably when trying to edit a sketch
2 REPLIES 2
jacslx
526 Views, 2 Replies
Hello all.
Yesterday, up until around lunch time, editing a sketch that was imported as a SVG file was going just fine. After lunch all progress ceased and Fusion crashes every time I tried do something. Cannot delete lines (when imported many lines were messy, so many lines had to be re created or deleted) Cannot add lines, cannot move lines. Basically I cant do anything.  I cant even generate a error log, it crashes also. I have searched and tried the following: selected DX9, unchecked the auto project edges, uninstall and re install. With no fix.
I am using a Gaming laptop i7, 12gig memory and a Nvidia 965 gfx card with 2gigs. Plenty of horsepower to run the program.
2 REPLIES 2
masa.minohara
in reply to: jacslx
Hi @jacslx,
Thank you for posting about the issue!
Could you submit a crash report when Fusion crashes next time? Also, would you mind recording a screencast of the steps that cause Fusion to crash, and share a public link to the design with me so I could test?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
jacslx
in reply to: masa.minohara
After doing some more research in my downtime I found that turning off the
History worked. .So I did and therefore I was able to continue my work.
Thank you.
Technology Administrators
