Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Fusion 360 crashing repeatably when trying to edit a sketch
2 REPLIES 2
jacslx
540 Views, 2 Replies
Hello all.
Yesterday, up until around lunch time, editing a sketch that was imported as a SVG file was going just fine. After lunch all progress ceased and Fusion crashes every time I tried do something. Cannot delete lines (when imported many lines were messy, so many lines had to be re created or deleted) Cannot add lines, cannot move lines. Basically I cant do anything.  I cant even generate a error log, it crashes also. I have searched and tried the following: selected DX9, unchecked the auto project edges, uninstall and re install. With no fix.
I am using a Gaming laptop i7, 12gig memory and a Nvidia 965 gfx card with 2gigs. Plenty of horsepower to run the program.
2 REPLIES 2
masa.minohara
in reply to: jacslx
Hi @jacslx,
Thank you for posting about the issue!
Could you submit a crash report when Fusion crashes next time? Also, would you mind recording a screencast of the steps that cause Fusion to crash, and share a public link to the design with me so I could test?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
jacslx
in reply to: masa.minohara
After doing some more research in my downtime I found that turning off the
History worked. .So I did and therefore I was able to continue my work.
Thank you.
