Fusion Support
nested asn1 error (_ssl.c:4003)
4 REPLIES 4
milan.krcadinac
1131 Views, 4 Replies
milan.krcadinac
I get this error nested asn1 error (_ssl.c:4003) when i try to install Fusion 360
any help is appreciated
4 REPLIES 4
jhackney1972
You need to post your install log files and also tell everyone what operation system you are using?
John Hackney, Retired
milan.krcadinac
Windows 10 home edition
and the log is attached
jhackney1972
Are you by chance located in Serbia?  Take a look at this post and see if it helps. Look down around message 11 in the post.
This is the line showing up in your log file often.
ssl.SSLError: nested asn1 error (_ssl.c:4003)
milan.krcadinac
@jhackney1972  oh wow thank you, it was cert problem after removing it Serbian MUP internal affairs certificate installation started.
I hope just i can get back the cert. It would be great if Autodesk would skip checking validity of our police cert because i guess they will never change it and get it right. they even made a mess regarding installation the cert.
Again @jhackney1972 , youre a life saver!
