Hi!
I have troubles starting up Fusion 360. I am on an educational license and it has worked flawlessly before. I am getting an error message during startup now telling me that my system time doesn't match server time. There seems to be an hour difference. My system time is set to my local time so I do not want to adjust my system time to a time other than my local time. I have reinstalled Fusion 360 as well. No change. I also deleted the login_startup.xml file from the library as recommended in the help section on this issue. Also no change.
I am running a 2015 MacBook Pro with iOS 10.15.4 if that helps.
Attached is a screenshot of the error message.
Please see if the solution here is what you need.
https://forums.autodesk.com/t5/fusion-360-support/unable-to-login/m-p/9488179/highlight/false#M87258
Let me know if that helps.
