I think that I have a unique situation and I have exhausted my knowledge.
Fundamentaly I have a decent computer with an Nvidia GTX 1050 Ti on two displays.
It seemed that I had a random problem that pointed to graphics drivers, but after a lot of hours of troubleshooting(clean uninstall&reinstall F360 & graphic driver) I reached the following conclusion.
99% of available drivers from Nvidia will work as long as I launch Fusion 360 on my primary(left) monitor and close Fusion 360 on the primary monitor.
For convenience sometimes I move my working window to the second monitor and continue use F360 then when I close the project and exit F360 if I forget to move the active window to the left monitor on the next startup of F360 will crash(like bad graphic driver). During the F360 launch I must move the F360 window to the left monitor so after the crash it can start on the left monitor without issues.
I am out of things to try and hoping that someone the community has an idea where i should look next.
Thank you in advance.
Solved by FrankSz. Go to Solution.
Is one of the monitors, non-primary, a 4K resolution monitor?
John Hackney, Retired
Both monitors are identical and running in 1920x1200 mode @Anonymous refresh and they are configured for photo editing by Spectraview(color balance,etc). I have also tried with Spectraview disabled, but without success.
This card meets F360 specs with it's total 4GB memory.
Reluctantly I have given up on the Nvidia GTX1050 Ti, since I tried 6 Studio drivers and 4 Game Ready drivers and the results are the same. I have replaced the card with a Radeon RX570 and the problem for F360 is now gone, the best part is that everything else is also working.
(Live & Learn)
I have an issue as well and don't know how to get support. I pay monthly for Fusion 360 on a Macbook Pro connected to an external 2k wide aspect monitor.
Every time I dock and undock Fusion loses it's S__T, secondary toolbars are all over the place and can't get them handled again until I close and reopen.
You would think they could either create a move feature for these 2ndary pop ups or a way to force everything to one window. I find this extremely annoying to be looking for why i can't perform the task, to find a 2ndary pop up is waiting for a reply on a monitor that i am not using for the design. AND WORSE it is under open windows on that monitor. Opening and closeing does not alway fix the isssue (if it reoccurs is it a fix), the underlying understanding of why it happened in the first time, is never clear and so the fix IS NEVER CLEAR. Fusion fix this.
