When I opened my drawings the mass in the parts list started showing up as blanks. How can I fix this?
The attached DWG file seems to be blank. Please attach your native Fusion 360 model instead of a DWG. If you do not know how to attach your model, open it in Fusion 360, select the File menu, then Export and save the file to your hard drive. In a Reply post, use the Attachment section to attach your model. The file type should either be a F3D or F3Z extension type.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Ok, I'll attach a much smaller file. The 3D model I used was huge and it's happening to all my drawing sheets. Thanks so much for your help.
I see your problem but I do not have a solution right now. I did take one or two components, from your assembly, and made drawings of them individually and the mass in the Parts List did appear. Still together, the mass is missing. I will continue to look at this, hopefully someone else will have some other input.
John Hackney
Retired
I have the same version of Fusion 360 as you and I do not see the issue with my assemblies. In yours, if all components are eliminated, except for the two pieces of channel, the Parts List Mass works. I do not have an answer for the rest of the components.
John Hackney
Retired
Could it be anything in settings or preferences? I just completed a clean design and I'm getting the same thing.
I have this feeling that is is a flaw in Fusion 360. Other reports are showing up on the Forum. Here is one. I am finding that this issue occurs on newer models as I do not see it on older assemblies.
@ClintBrown3D, can you have a look at this, Thanks
John Hackney
Retired
Hi everyone
I’m sorry to hear that you are having trouble, I've asked the team to have a look.
Please share downloadable links to your affected drawings, so that I can ask the team to investigate this, or if it is sensitive, feel free to send it directly to me Clint. Brown {a} Autodesk.com
Your files help us find and fix the issue.
cc: @Pramod.kadam @-KyleWilliams- @nemadec
I have attached (4) files, model and drawing, before and after the problem showed up. PS01A is before, PS27 is after. Since there is a max upload there will be 2 replys. If you need any additional information please let me know.
Thanks for sharing, I will pass this on to the team to investigate.
I found 2 other issues.
1. The "Reference Angle" option has gone missing in the drawing command.
2. When I try to "Save Copy As", a new file is created in the data panel but when I open the new file it is blank. I have attached (3) files. Main file - SUPPORT STRUCTURE, File saved before update - LOWER STAIR, File I tried to save this morning that is blank - MID STAIR.
Thanks for reporting these:
cc: @nemadec @-KyleWilliams- @Pramod.kadam
Hi @jldriggers75 ,
1. Please update the Fusion to 2.0.16486 version, The reference option is available now in the Rotate command.
2. Regrading Save as: The files which you have shared are only design files (without drawings). Are you talking about save as on design files or drawing files? I tried 'Save as' on both design and drawings on my end, it works perfectly fine.
Please try again at your end and let me know.
