Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Manufacture Simulation - cannot fully turn off tool
4 REPLIES 4
cyberreefguru
375 Views, 4 Replies
In the most recent update, you can no longer fully turn off the tool when simulating.  There is a magenta square where the tool contacts the material when the tool is "turned off".  The tool shows properly when turned on.  See screencast.
Professional PowerPoint Jockey...
4 REPLIES 4
Screencast is missing.  If you have issues getting it to insert, just use the Link tool.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
doesn't seem to be a way to edit the post.  here's the screencast.
Still there is no screencast. I think you should post this in the manufacturing forum if it is CAM related.
https://forums.autodesk.com/t5/fusion-360-manufacture/bd-p/2070
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
I just wanted to do is post the bug report - when I add the screencast, all I get is:
"Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied."
There has to be an easier way.
Technology Administrators
