Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Make components lightweight
4 REPLIES 4
dcAWMGX
484 Views, 4 Replies
Hi.
would it be possible to add a toggle to make components like fastners lightweight in an assembly. This way fusion would not get choked by fastners in the assembly.
best regards
Dan
4 REPLIES 4
jeff_strater
in reply to: dcAWMGX
can you add some more detail here?  What would make the fasteners lightweight?  Are you talking about just removing modeled threads on the component?  Or, are you talking about removing fasteners completely from the model to make it lighter?
We have no plans for anything like this at the moment, unfortunately.
Jeff Strater
Engineering Director
dcAWMGX
in reply to: jeff_strater
I’m coming from ansys spaceclaim and it has the feature. How it is actually doing it i don’t know. I would just like to be able to remove fastners when working with the assembly, but still show up on the bom. And then could turn them on for rendering,
when having 30-40 sheetmetal parts the is assembled you easily end up with 1000-1500 fastners and every time you make a change or create a drawing it recalculate everything in the timeline and it is a slow process.
jeff_strater
there is really nothing exactly like that.  There is "Select by Size"
which you can use to select small components in your design.  You can turn them off, which reduces visual clutter, but they are still in the model, so any performance advantages are minimal
Jeff Strater
mjohnson.cps
Hello
I just wanted to add that this would be a very useful feature
It is an option in Solidworks, intended to be used working with larger models and it allows the system to load the parts with reduced data for the selected parts.
This allows a larger assembly to be created on a given machine
I find Fusion gets quite slow when there are a few hundred components open...
