Fusion Support
embossing shx text on a curve
5 REPLIES 5
ernieflash
232 Views, 5 Replies
I am trying to engrave shx text on a curve and just cant seem to make it happen
please help
5 REPLIES 5
jhackney1972
in reply to: ernieflash
SHX fonts are single like fonts and do not create a Profile which is required to use the Emboss command.  The attached video is on the process you could use to accomplish your task.
Edit: Video did not upload, check back is a second.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
g-andresen
1. Engraving is not possible with single-line fonts.
2. The "Trace tool" can be used for single line fonts. However, the font must be converted to paths via Right-click > Explode
günther
ernieflash
in reply to: jhackney1972
when I do what you tell me only partial letters extrude and i am extruding on a cylinder i think tha
t might be different
g-andresen
Here´s a simple tracing on cylinder.
Of course, this works better with a fourth axis.
please share the file for reply
File > export save as f3d on local drive > attach to post
günther
jhackney1972
All fonts are not reliable as far as creating entities when exploded.  This is the fault of the font and not Fusion 360 or the process.  Here is Romans.shx font extruded and trimmed to a cylinder.  Model is attached.
John Hackney
Retired
