I am new to fusion and I am searching for simply changing the line color in sketch since 30 minutes now. The post I could find tells something about document settings but I can't find them. Does somebody know ? Why is it so difficult? What I actually want to do is to redraw a sketch on top of an imported dxf sketch (as I can't extrude that - for whatever reason. A help at that end would appreciated as well. Thanks
I look forward to you posting a Fusion model with a model sketch with multiple colors. I need to learn this magic trick you have.
John Hackney, Retired
Boo! I do not think that is what the OP wants to do.
@jhackney1972 wrote:Boo! I do not think that is what the OP wants to do.
@banalo wrote:What I actually want to do is to redraw a sketch on top of an imported dxf sketch
Did exactly what @banalo stated. (See Attached - I sketched slightly offset so that you can see the trick in the "magic".)
@jhackney1972 wrote:I look forward to you posting a Fusion model with a model sketch with multiple colors. I need to learn this magic trick you have.
Click on image above to enlarge the view. Note green geometry and blue geometry.
Of course what @banalo should probably do is Divide and Conquer.
Farben in Skizzen sind nicht frei wählbar sondern von der Voreinstellung festgelegt.
günther
thanks- indeed this is what I wanted to have - different colors so that I can draw more easily on top of that dxf. So how did you do it, then ?
