Fusion Support
How to design an O ring groove
8 REPLIES 8
Message 1 of 9
memo2022
424 Views, 8 Replies
Hi guys,
How to design circular O-ring groove inside an object? thank you
8 REPLIES 8
Message 2 of 9
HughesTooling
in reply to: memo2022
Do you mean in a hole? Create an axis through the hole, then a plane at angle using the axis then sketch the profile of the o ring groove and use a Revolve cut. Or create an offset plane from the end of the hole, then sketch a circle and extrude.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 9
g-andresen
try this
günther
Message 4 of 9
memo2022
in reply to: g-andresen
Thanks, How to make the o ring in certain diameter for example i do not want the o ring in the edge but closer to the middle instead of 100mm in the edge of tube i want it to be 50mm in the middle of tube
Message 5 of 9
memo2022
in reply to: HughesTooling
Thanks mark, i tried not working. Can you make video making an example of depth, id and o ring. I do not want the o ring to be in edge but 10mm from edge of the object. much appreciated
Message 6 of 9
HughesTooling
@memo2022 Sorry can't make a video but I've attached a file with both methods I suggested above.
First one creates an axis then a plane and sketch then revolve.
Second uses an offset plane, sketch then project the edge of the hole and offset before extruding. If you step along the timeline and try editing the features you should be able to figure out what I've done.
Mark
Mark Hughes
Message 7 of 9
g-andresen
1. change the offset distance
2. create a circle and use it for split face tool
3. please show your object and mark the desired position
günther
Message 8 of 9
memo2022
ow to choose the depth of O ring groove?
Message 9 of 9
g-andresen
depth = pipe diameter/2
günther
Technology Administrators
