This crash is repeatable:
1. I open a part and it's new revised part in Fusion.
2. I copy the machining operations from the part to the new revised part
3. Save and close the new revised part, close the part without saving.
4. In Windows explorer I move the original part to a backup folder within the same cloud root folder.
5. Fusion crashes.
I'd also like to note, Fusion crashes if after step 3 I open another unrelated file before proceeding to step 4.
Another note, Fusion crashes if I create a new file, save, then move that file. So the problem is how Fusion is handling recent files, the history, not closing files completely or any other process I do not understand.
I hope it helps. I'll keep adding details if I find anything else that might help.
Solved by RajkumarIlanchelian. Go to Solution.
@matt.fame Thank you for reporting this crash. When you crash are you sending the crash error report to Autodesk? If so can you send one and report the Report ID here please so that we can look at the crash report as well?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I have submitted several reports with increasing details as I realized what was going on. Matter of fact, most of this text above was copied from a crash report. Since it's so easy for me to replicate check out Report ID# 721862527
This is a new file, created a sketch with an undefined circle.... saved.... moved to a backup folder in the cloud and crashed.
@matt.fame Thank you for the report ID. I was able to pull out all the reports you submitted. This is a crash issue that we are validating a fix. We are hoping we could release an update as early as this Monday. Will certainly keep you updated on the progress. For reference the internal tracking ticket is FUS-138670
Autodesk Fusion
Join Fusion Insider
@matt.fame @Can you please update to 2.0.17457 and confirm that the fix worked for your workflow?
Autodesk Fusion
Join Fusion Insider
I did update a few days ago and noticed this problem was gone. I did not notice it specifically in the change log so I hesitated to get too excited.
This crash appears to have been resolved. Thank you for the help and quick resolution.
