In Mac iOS BigSur 11.4: When I have Fusion loaded and running in the background the Fusion browser keeps overlaying itself on top of other applications running simultaneously. It can be cleared by clicking on the original app but this is a real pain and should not be happening.
Others having this problem?
Hello @rlenicheck ,
Sorry for the trouble, this is a known issue and out team is already working on this issue.
Thanks!
@mohammed.aliTDPXK @jodom4 is there any update on this issue after all this time?
This bug has been present for well over 1 year. And there's many reports:
https://forums.autodesk.com/t5/fusion-360-support/fusion-mac-issue-with-browser-displaying-over-othe...
https://forums.autodesk.com/t5/fusion-360-support/browser-does-not-disappear/m-p/11236248
https://forums.autodesk.com/t5/fusion-360-support/browser-rendering-on-mac/m-p/11406261
If you search the forums there's actually many bug related to the browser on Mac. I think I've experienced them all at one time or another 😅
This is a bug that we cannot reliably reproduce. When tested internally, 9 times out of 10, the browser disappears as expected. That last 1 time, it happens doing the exact same thing we did the other 9 times.
If you are able to pin down any steps which can reproduce reliably, please let us know. I speculate that the order or way in which the Fusion app window is interacted with relative to other apps may be a factor - possibly monitor layout, too. Timing may also be a factor. If you are able to include a recording showing what you were doing leading up to the bug reproducing, that may also be helpful.
Thank you for your patience while we track down this annoying browser quirk.
I can reproduce it reliably.
In my setup the key thing is to have the external screens woken up by the mac, then the mac unlocked, then the issue is there every time. If the external screens don't go to sleep (black screen) and then get woken up again, for example if I lock my mac and unlock it before the screens go to sleep, the issue is not present.
My setup:
So this is how I can reproduce it:
I wish this would get fixed. So annoying to have the browser on top of the rest of my applications..
The Mac's window server has a mechanism for grouping windows so the OS takes care of ordering and moving them together. It's there to prevent these exact kind of race conditions. Is the component browser setup as a child of the canvas window?
@bentwookie no, actually we make use of the Qt::Tool flag for most of Fusion's floating palette windows. This worked great historically, but has slowly broken down since about 10.14 Mojave, especially with Spaces and app window switching. MacOS really likes to treat these Tool flags as individual app windows now, much to our chagrin.
There is an ongoing effort to refactor away from this flag and let macOS do the work for us, but it's been a tricky process that risks introducing new regressions in the process of solving others.
This affect happens for me 100% of the time, even on a brand new MacBook Pro with no other software installed. Just install a fresh Ventura 13.1 and then install Fusion360. I have two physical monitors and use virtual windows.
It's super annoying since Fusion is using two virtual windows, one with the main application and the other with just the nested list of bodies, components, etc. overlayed on another app. Every time anything happens in Fusion it switches the virtual window to the overlay and I have to switch back. This happens hundreds of times a day, and has been happening for years 😞
This is a good example (just happened to me):
I'm trying to develop an add-in for Fusion 360 and Fusion's ui is obstructing the debugger so I can't see the add-in.
And the usual "fix" of cmd-tabbing back and forth to Fusion does not work because Fusion is busy being debugged..
Any updates on this? Happens when waking Macbook Air (Apple silicon, latest OS) from sleep. Happened with previous Intel MBP.
It's been a consistent problem for at least 3 years now. It happens 100% of the time when waking from sleep, so it's completely reproducible.
This is also reliably happening to me with the latest Fusion 360 and Mac OS 12.6.5 - it's also been happening for the last few years, consistently, with every recent version of Mac OS and Fusion 360. It reliably happens after waking from sleep, but also pretty often after just starting Fusion 360 and using any other open window.
also checking to see if there is an update. Still happening 5/19/23 and it is really—really annoying.
Any updates on this? Why does the browser overlay have to be free floating in the first place? Is that a feature people even use? Probably a lot of people would appreciate if this get fixed, instead of having the ability to have the panel free floating... right now it is a constant reminder that Fusion on Mac isn't really fully supported.
They claim they can't replicate it, which is interesting, because it's happened consistently for several years on multiple Mac laptops through several versions of Mac OS and Fusion 360.
