I want to create a seat & would like to start with a flattened box form. Unfortunately when I add the box I get no opportunity to flatten the box or change the number of faces. Not sure what I'm doing wrong. Check out the screencast.
Solved by jeff_strater. Go to Solution.
my guess is that you are zoomed in too close to see the on-screen UI. Can you try zooming out? As for the dialog, have you ever used Fusion with a second monitor? If so, try Reset To Default Layout:
Well I'm back...
Thought this was a zoom issue but it returned. Tried resetting my view but that didn't work..
Any other suggestions would be appreciated. https://autode.sk/3iapKJT
