Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Form preview not given
5 REPLIES 5
wesley.bonafe
198 Views, 5 Replies
I want to create a seat & would like to start with a flattened box form.  Unfortunately when I add the box I get no opportunity to flatten the box or change the number of faces.  Not sure what I'm doing wrong.  Check out the screencast.
5 REPLIES 5
Here we go again.  No screencast. https://autode.sk/3ce1UJl
That ran for me.  Hopefully it will for you!
my guess is that you are zoomed in too close to see the on-screen UI.  Can you try zooming out?  As for the dialog, have you ever used Fusion with a second monitor?  If so, try Reset To Default Layout:
Jeff Strater
Engineering Director
Apparently I was zoomed in to close.  Thanks!
Well I'm back...
Thought this was a zoom issue but it returned.  Tried resetting my view but that didn't work..
Any other suggestions would be appreciated.  https://autode.sk/3iapKJT
Technology Administrators
